Hi can any one help me ? I have a mk1 2.0 ghia but resonly the driver side heated screen has stoped working ?? Is there seperate power to each side of the screen are is the something else that may be the problem ,Many thanks Paul :thankyousign:
You need to break the seal between the spindle and the arm caused by corrosion, just turn the wiper from side to side as though you are trying to wipe the screen while at the same time trying to pull it outward off the spindle, this usually does the trick, as a last resort you can use a puller and there is a special type available for wiper arms.petep900 said:Any tips for getting the wiper arms off the spindles to get at the connector plugs? I have the same windscreen heating problem and can not get wiper arms off (after nut removed!) as they must have been on from day one!
Tried usual careful levering with spanner but all I can hear is the plastic protesting and I reckon it will break if I put too much leverage against it.
