Hi there,
Usually a heated front screen is split in two sections, left and right. There are fuses for each section. It is very well possible for only one section to break. To me it happened twice. One time with a brand new window!
You could check the connections to the window. On a MKI and MKII these are situated under the plastic cover under the screen (the pieces the wipers go through). You will have to remove your wipers. This isn't to hard to do. Just loosen the bolt a few turns and than lift the wiper and rock it gently up and down (to and from the screen). This way it will come loose. The screws that hold the plastic bits are covered by little caps.
Good luck.
Christiaan
