all i can tell you is that if you go into the boot and remove the plastic covers you can use pliers to pull the cable and open it
Great thanks, how quick could you post them out please; I'd need the sensor for the lock push relaease.xxfordxx said:if anyone has any problems i think i have the motors and sensors as a replacement if you need them..
Thanks, so if I swap the sensor that should then enable me to press the lock to open the boot again?xxfordxx said:ill put a for sale post in the sale section and you reply to that!!
"everything in its place and a place for everything"
sensor
http://www.fordmondeo.org/forum/showtopic.php?tid/830086/
motor
http://www.fordmondeo.org/forum/showtopic.php?tid/830087/
£22.50 for the both posted!
