1 - 2 of 2 Posts
Need help if anyone has come across this problem
2011 1.6 tdci 90ps 8 valve
Loads of Faults on arrival including crash occurred, clear and reset all faults, car started after several attempts and idled fine for 10 until I turned the car off and ever since it will not fire up, turns over fine 1 fault appears every now and again
1, glow plug sense faulty signal
Rail pressure is ok
Rpm while cranking over average 220 rpm
Changed cam, crank and rail sensor
diesel filter
If I give it a sniff of easy start it will fire but will not run on its own
All advise welcome
What is the actual rail pressure when cranking? Are the injectors firing?
Have you checked for faults with an OBD reader, preferably one with live data.
1 - 2 of 2 Posts
