1 - 11 of 11 Posts
Hello forum,
2012 (62) Mondeo Titanium 2.0 Diesel Powershift
Lately i've been experiencing an engine malfunction warning light when sat at a steady constant speed, with a loss power. Turning the engine off for a few minutes clears it, until it returns. I've looked under the bonnet for split pipes etc and spotted this rigid black pipe that is coming from the back of the righthand side of the engine under where the airbox is.
I've traced it back to the top of the gearbox and it is broken at that end so it isn't connected either end! What is this pipe called, what does it do, and where does the end with the bend in, at the front of the engine, actually connect to?!
Anyone got the same make and model that might be able to pop under the bonnet and take a look for
me?
I then know what to call it when I order a replacement. It might not be the cause of the engine light fault but it needs replacing, regardless.
Pics added are one of the front with the bend, one at the back where its broken, and one from above for reference.
Thanks for any info.
Steering part Cable Electrical wiring Gas Wire
Automotive tire Automotive design Motor vehicle Automotive lighting Steering wheel
Automotive tire Motor vehicle Personal luxury car Automotive exterior Gas
Anyone at all? I cant be the only one here with the same make and model? the part number for the hose is AG9N-7B344-BA but brings up nothing that tells he where it connects to
Mondeo MK5 Titanium 2.0l EcoBoost
after looking on google I found that part number corresponds to FORD VALVE VENT AG9N7B344BA. I would therefore check the inlet manifold and air intake for a broken/missing pipe.
I would assume it's the vent for the gearbox and would attach after the airflow is metered. Air getting added after metering could well explain your loss of power.
Sorry probably not much help
Discussion Starter · #9 ·
Thanks for the suggestion, will take another look tomorrow. It definitely starts at an outlet from the back of the gearbox (although that connection is broken) I will look around the areas you suggest to see if I can see where the other end might connect.
Thinking of calling my local Ford dealership parts dept tomorrow, now that I have a part number to go on.
1 - 11 of 11 Posts
