1 - 6 of 6 Posts
Wanna do a boot install and wanna still keep standard head-unit, pulled it out and have no RCA jack points, so wheres it go? which wires do i splice onto? also which wire is the remote one to turn the amp on?
:thankyousign:
wbumanagh
I did the same thing. Had to get a Speaker to Level converter. £10 well spent. You have 5 wires to connect, 2 for front left, 2 for front right and one to ground. Then you have the Pre outs for the amp. Attached is a diagram on the speaker wire colours hope it helps. This is for a Mk3 BTW.
Its a 5000rds with the tape player but also has the stick on steering wheel and the 6 disk multichanger
1 - 6 of 6 Posts
