Hi All
New to the Forum, been reading as a guest for a while though, great place.
I have a MK7 Zetec S tdci, which now has electrical issues it seems. Immobiliser flashes code 16, which i believe means
no power to PCM. Weirdly, when i tried to pull the relays to check them, as i squeezed with grips to remove the starter
relay to get it out, car tried to turn over (without keys in ignition). Does this mean i have power to fuse box, but
fuel pump/glow plugs/etc are being held off by something ? Lack of power to put all relays and PCM into normal state
to operate?
Can't seem to even locate anywhere i could get a wiring diagram from, and i believe Haynes manuals no longer cover these ?
Any help appreciated, before i burn the things
Stuntmaneddie
to operate?
Stuntmaneddie
