Yippee! Someone else with the same workaround on a 2006 car, do you get the slow, chugging 500 rpm idle if you don't use 1" of accelerator pedal?
a bit so sometimes when hot, bur perfick when coldMicky said:Yippee! Someone else with the same workaround on a 2006 car, do you get the slow, chugging 500 rpm idle if you don't use 1" of accelerator pedal?
Yes .... according to Frod.ojobson said:Is the 06 that much different to the 05? My 05 did this and got worse and worse - PCM update did wonders.
