Even if you take the Ford badge off of the grille, there is a plastic moulding behind it with the keyhole for opening the bonnet. You'll need to modify the grille inners to successfully de-badge.
You could PT a member on here called spooj (have a look at his car in the multimedia section - have a look here: http://www.fordmondeo.org/forum/showtopic.php?tid/828756/ ). He has done the mod you want.
Hope this helps.
Lee :L
Hope this helps.
Lee :L
