If its the same design as the Fiesta etc you start by removing that large top section.
Use proper plastic trim tools to prevent marking the surrounding trim.
Pop that out and the screws are usually there.
Google catcar and see the exploded diagram of the cover, should show you where
the trim fixing tabs are located.
Hood Motor vehicle Vehicle Car Automotive design Gadget Musical instrument accessory Output device Electronic instrument Camera accessory
Hi
A couple of pics borrowed from eBay that might help, first shows bar dash opening. This suggests top cover has to be pulled forward to remove. The second is only picture available for display, this shows potential fixing holes along bottom of unit. Not sure how you will access these.
However this vid shows a different model with cover being removed by prying up from the top:
Another vid that might give clues:
Peter
