1 - 2 of 2 Posts
anyone know how to change them? is it an easy job i would like to do it myself.
also anyone know how ti change the ball joint?
i have a mk2 1.8 td
TDDI Buff
drop links easy just undo and boltthe new ones on if you look at them they are straight forward. on the front ones push the rubber back a bit to reveal 2 flat edges stick a 17mm spanner on to hold it still and undo the nut, the back ones are easy self explanatory.
ball joint im presuming wishbone if so then you need to drill the round river things out but its probably better to replace the wishbone but thats upto you.
1 - 2 of 2 Posts
