I am trying to sort an issue with my fuel line where I get air ingress in the feed pipe to the fuel pump. I have found what I believe to be a 3-way connector that seems to be a check valve, see pictures. Can anyone confirm what this is and what its purpose is? Thanks in advance, Dave.
257746
257747
Posted in the wrong section, what vehicle/engine is this for?
Hi, no the picture shows the fuel feed to the fuel pump and the cinnector you see about 15cm from the end is a check valve that connects to the leak off return pipe. Its like an H shape when connectes. It allows flow from the feed pipe to the return pipe and blocks flow from return pipe to feed pipe. Complex to explain. Herw a picture of it in situ. The top pipe is the feed to the pump and the bottom is return pipe. 8hrs
257754
