Well someone locked the previous thread (any reason why?) so i've had to create a new one.
27-12-06 11:11 PM - Post#1102171
In response to percyt
* percyt Said:
Hi there percybigun,
Can you let me know how to bypass the immobiliser as I might be having the same problem as you.
I'm going to do the soldering tomorrow but if it don't work after that - i'll need to bypass it.
Many thanks,
Darren
E mail sent m8.
Just a little pointer here to save you some diagnostics cash !!
If the Bosch system is faulty then any Ford fault reader will not communicate with the ecu or any other part of the ignition system. This is because the Bosch system works on the fuel pump, injector primers and the starter motor. SO, word of warning is that if your ford man says your ecu is fubared as he cant communicate with it, check the bosch first !!!!!
MODDING IS FOR FOOLS
STANDARD CARS ROOLZ
Citrine site is here
http://www.freewebs.com/anglianut/index.htm
Recieved Anglianut's mail and although I can hear the fuel pump prime - the car fails to start. :thumbdown:
I'm bridging the right side as there needs to be 6 wires and the other side has 5 and i've rechecked the document that Anglianut sent me so now i'm a bit knackered!!
So if someone could get back to me either on here (I check at least twice a day) or get me on msn percyt2k at hot mail dot com i'd be greatly appreciated!!
Many thanks,
Darren
E mail sent m8.
STANDARD CARS ROOLZ
