The engine management light will come on if your EGR valve is blanked off because it's a Euro 4 and has a sensor for detecting gas flow. You can safely ignore this and there's a few people who just live with the light on because of the benefit of running with no EGR.
Glow plug light mainly comes on when there's a problem with the fuelling and injector system. Most people first try a new fuel filter first because its cheap and sometimes fixes the problem. Since you've got an OBDII compatible Mk3 you can pick up a cheap code reader and plug it in to see what errors are being thrown up rather than pay a garage to do the same.
