My speedo' has started to drop back to zero intermittently. When it comes back on again, the low fuel warning light comes on for 3 seconds, as it does when you turn on the ignition. This makes me suspect that the problem is with the power supply to the instrument panel. Loose connection? Faulty voltage regulator?
