I recently bought a 2006 Ford KA 1.3 (only 22,000 miles!) for my son. When moving at low speed/low revs the steering is very heavy (parking is really hard) but when driving around or when keeping revs higher it is OK.
I suspect a pump issue which can be replaced cheaply enough, but before going to the effort of doing that I wondered if anyone had some ideas to try/test first.
I have:
Flushed and replaced fluid. Was quite black before, now red and clear.
Checked drive belt which doesn't squeal and looks in OK condition.
Found no fluid leaks.
Pump makes a little noise at full lock, but that seems to be quite common on old cars in my experience and is quiet otherwise.
Anything else I might have missed before I order the special tool to pull the pump pulley and taking things apart?
Do you need to take the pulley off? some replacement pumps (not sure if appropriate for your car) come complete with a pulley.
Either the pump is worn or the internal relief valve is stuck partially open - that would explain the usable pressure at higher revs
All the of the guides I have looked at say one of the bolts is obscured by the pulley so it has to come off to get the pump out. The puller tool is only about £15 so it's not going to break the bank.
I think the same about the pump too, but on a car that has only done 22,000 miles I'm expecting more likely stuck than worn.
I think savage garage did one on utube if you needed any guidance
