Sorry wrong post.
Kop,kop said:Had my 08 Mondeo since December 2008 with no problems.
I have keyless entry and button start. Today I got out of the car and it wouldnt lock. So I pressed the lock button and nothing.
Also car would also not re-start, it came up with key not detected. Went in doors and got spare key. Everything worked fine with this.
My query is:
1. Will Ford Charge me a fortune to replace the battery. Its due a service next week.
2. If I wasnt at home and didnt have the spare key. Would I not be able to actually start the car!!! This is alarming!!
Anyone who can help I would be appreicated.
Really, well thats a wazz isnt it. Just had to try it, and your right. As tellmah suggests, I've now put a spare battery in the car.kop said:Mine didnt!!!
Said it couldnt locate key on dassh
At this point the manual suggests you pull the blanking plate off the steering column and insert the keyfob into the slot designed for it.kop said:Mine didnt!!!
I had to ty it and indeed it does.silo24 said:At this point the manual suggests you pull the blanking plate off the steering column and insert the keyfob into the slot designed for it.kop said:Mine didnt!!!
It should then detect the key.
I sort of guessed this could be the case, and was going to try it well away from any populous in case I didnt get the cover off and start the car in time before the alarm went. Ok I could have tried it on the drive. I guess you've been theresilo24 said:If after you opened the door and the alarm was going off, once you inserted the keyfob and hit the start button, the alarm should silence.
Kop,kop said:Ive had the car since early december 2008. It was 6months old b4 that...so I would say the batter has lasted 2 years!! I got no warnings about a low battery on my dash!
I got in the car at work. Arrived home. When I got out I tried to lock it and the fob didnt work. Got spare Fob and everything was ok....So no I cant answer your question.
I brought a Duracell Battery to replace the flat one. The fob went dead thursday eve and I put the new battery in today around 1.30pm
