Hello, I am a mondeo mk5 owner, but the seller could only provide me with a key. I got one on aliexpress that is theoretically compatible. Can I program it myself? I currently have forscan, or should I go somewhere where it can be cloned?
ford use a system where you need a minimum of 2 keys to programme the third, the only workaround is buy some extra transpoders as its that its really looking at, Cloning in much easier but you cant use a cloned transpoder if there is already a transponder built into the remote board, for a simple key cloning is the easiest way, not all makes can be cloned but fords are clonable
Ford removed this feature several models ago, you now need correct hardware and software to get car and keys working together. ( Or a local yob who can probably drive car away without a key )
Peter
Related Threads
Ford Automobiles Forum
2.3M posts
120.3K members
Since 2001
