Knocking from rear Off side..NOT subframe
484 Views 6 Replies 6 Participants Last post by  Baldrick
Just replaced the rear subframe and bushes as i thought the knocking coming from the rear drivers side was that.....but it turns out it wasnt...
There is a very slight knock coming from the rear drivers side of the car when going over a slight bump....
What could it be, As said, not subframe bushes as i have just replaced them all
1 - 7 of 7 Posts
Check the drop link on that side....mine does the same and it turned out to be the drop link.
Also check the trailing arm bushes and handbrake cable as they can knock against the trailing arms. :driving:
cheers chaps, will take a look
I had the same problem and it was the drop link :)
was the brake cable on mine, but also noticed the rear lower plastic had play.
1 - 7 of 7 Posts
