There are 4 sensors on the V6. The codes you have are saying that the post-cat sensors are faulty not the pre-cat ones which you appear to have changed.
Bank1 is the back of the engine as you stand looking at it from the front of the car. Firstly, I would check that the wiring is ok from the sensor as I have seen a wire wear through in the past that was not held up properly.
If the post-cat sensors go, you should see no driveability problems with the car as they are only used for monitoring and do not affect the engine management or emissions.
