1 - 7 of 7 Posts
Hi All,
I'm going to be replacing all my braked pads & discs in the next few days and was wondering weather it's a left or right handed wind back tool i need to wind the calipers back on my Mondeo?
2008 2.0TDCi 140BHP Hatchback
Thanks!
Where are You, I did all the discs and pads on mine on Sunday. If your near Guildford you could borrow mine, works on both sides on the rear (didn't know there was a left and right), however the front it doesn't work as the bore is huge. I easily squeezed the fronts in with a pair of grips tho.
i believe you only need the wind back tool on the rear anyway. The front i usually do with a bit of flat plate across the piston, and a clamp. I have used a small grinder spanner, and plumbers pliers to wind them in before, but be careful of the seal, and put a bit of pvc tape round plier jaws to stop them marking the piston.
Its a right hand thread, so you'll need to turn the rear pistons clockwise to retract them into the calipers.
  • Like
Reactions: andyjstew
8 gears or more please
Yes, only needed on rear. Right hand thread. Just done mine. Bought the full wind back kit off e bay, only £15 ! Brill
1 - 7 of 7 Posts
