1 - 1 of 1 Posts
Hi all,
I bought my Puma 1.7 millenium back in August and the Lights on alarm,door open indicator,door open indicator and when the door opened courtesy light came on all worked,but when I tried to change the stalks initially from an older model Fiesta,which blew the fuse, then I put the original back on,since then none of the above have worked, I have checked all bulbs and fuses and everything else is ok,I have been told that it could be the "G.E.M" Module but not sure where this would be or how to replace/reprogram this so any help would be appreciated,thanks in advance.
1 - 1 of 1 Posts
