Do you need to use the activated mesh that comes with it?
M Mark1984 · MEG Admiral Joined Apr 27, 2006 · 2,658 Posts Discussion Starter · #1 · Dec 6, 2006 Only show this user Do you need to use the activated mesh that comes with it?
W Wi11 · Big Megger Joined Oct 4, 2006 · 211 Posts #2 · Dec 6, 2006 Only show this user Yup it gives the glue a better surface to bond to, Will work without but may not stand up to the sunlight/heat of summer tho! Will
M Mark1984 · MEG Admiral Joined Apr 27, 2006 · 2,658 Posts Discussion Starter · #3 · Dec 6, 2006 Only show this user Cheers mate :L
M Mark1984 · MEG Admiral Joined Apr 27, 2006 · 2,658 Posts Discussion Starter · #4 · Dec 6, 2006 Only show this user Whats the see thru strip for?
P petep900 · Registered Joined Nov 9, 2006 · 273 Posts #5 · Dec 6, 2006 Only show this user I just used five drops of cheap superglue. Stays on and holds a badgers tail as well...
S squelch · MEG Colonel Joined Dec 27, 2001 · 5,987 Posts #6 · Dec 7, 2006 Only show this user petep900 said: I just used five drops of cheap superglue. Stays on and holds a badgers tail as well... Click to expand... you might have to order a new screen in the summer then superglue expands and contracts at a different rate to the glass and can cause it to crack
P petep900 · Registered Joined Nov 9, 2006 · 273 Posts #7 · Dec 8, 2006 Only show this user Oh B*gger.... Good Job I have Glass Replacement Insurance then! :L
M mondeo.man662 · Registered Joined Dec 5, 2005 · 3,032 Posts #8 · Dec 10, 2006 Only show this user £60 excess tho bud, just get it off and clean the superglue off n use sum loctite :L
M Mark1984 · MEG Admiral Joined Apr 27, 2006 · 2,658 Posts Discussion Starter · #9 · Dec 11, 2006 Only show this user yeh its spot on.. better then those pad things
