1 - 12 of 12 Posts
Hello this is very strange
I also have the famous ticking noise like all v6 mondys have. And i told already in previous posts that it comes an go.
Ok now it a go again but it gets louder now even in idle
But when i turn my steering wheel it gets really loud. Could it be somthing with the power steering pump?
Its just a question
greetings Freeck (Holland)
ST200 baby
well you say it gets louder when you turn your steering wheel , do you mean on full lock or do you turn it a touch and it will tick , a tick to what you are saying is could be a number of things but the things i know of that happen on the V6 lumos are head gasket / dogy exhast manifold / loud fuel rail / coil pack / dogy water pump tensioner / idle tensioner / idle pully.
they are what i would check but most of them is due to headgasket and exhast manifold.
My engine makes a very slight ticking noise at 550rpm. I just assume its a hydraulic lifter. As soon as I touch the gas it stops. My Mitsi Galant V6 did exacaly the same thing.
With 24 rockers and lifters I guess 1 of em will make a noise, lol.
Chris
ST200 baby
Chris
thats very true as well , forgot as well you have 2 chains as well witch can make a little tick maby..
Gets louder when you turn the PAS, this could be the Auxiliary belt tensioner is on the way out.
A few people have reported the tick disappearing with a new one.
My aux belt top idler pulley was making a ticking noise when the bearing in it was worn got it replaced and the ticking stopped.
I had hydraulic lifter noise, flushed the engine with STP and was amazed at the crap that came out, ticking wentI'd even been changing the oil every 5000km, for 7 years so I guess a lot of slow running is extra bad
Ex-Ford owner
Tensioner for the waterpump belt?
My 2.5 had a tick, with the engine running i could stop the tick by increasing the tension on the belt... ie, by pulling on the tensioner.
Speaking to Dave @ Autocraft he says this is a common thing.
1 - 12 of 12 Posts
