On a packed dark,wet motorway tonight I ran over a large steel object at 70 ish mph as was impossible to avoid.
The result is a smashed undertray-was wondering how much this will cost ???
The tray actually saved (fingers crossed) the aircon stuff inside the wing as you can see pipes close to the road on the drivers side.
The bit that is actually smashed off is not the smooth aerodynamic part but the shield closer to the sump etc.
Why do these things happen at this time of the year when you could do without the expense
Thank you
Thank you
