I've found out a new trick for the intermitten wipers on my car and I was wondering if the same would happen to the mondeo.
As my car is bottom of the range, it only has the 3 speed wiper settings, intermitten, on, and fast. I've recently found out that I can manually change the speed of the intermitten. Obviously this doesn't apply to cars with the 6 speed wiper thing.
Anyway, the trick is, switch on the intermitten wipers (wipers operate once), then switch them off, wait for the desired time (eg 5 seconds) and then switch them back on. The wipers will then operate at 5 second intervals. If you do the above procedure but wait, say 2 seconds, they'll operate at 2 second intervals, and so on for ten second intervals etc etc.
Please note, my car is a MK3 Golf and I was wondering if this trick would work for any of the mondeos on here?
Give it a go!
Give it a go!
