Just got in my car and this is the display.
I've tried the hold set/reset until test appears and nothing and I've tried to look up the error code without luck.
Any ideas what the problem is and what my next move should be.
Speedometer Car Trip computer Tachometer Odometer
You could try a system reset by disconnecting the battery for 5mins. Disconnect the battery negative lead. Make sure you have the radio code if it's needed. Reconnect the battery and see if that clears the vfault.
