The other thread got deleted in the database errors unfortunately so I'm putting this back up
MK1 & 2 (93 - 00) Lower Arm/Wishbone Fitting Guide (Nearside)
What Do I Need?
2 x Lower Arms (Left & Right)
4 x Bolts (Finis: 6203229)
4 x Nuts (Finis: 6797866)
Jack & Axle Stand
Torque Wrench
Power Bar
Ball Joint Splitter (optional)
Pliers
Long Screwdriver
Punch
Copper/Rawhide Hammer
Ratchets
19mm Socket
18mm Socket
17mm Socket
15mm Socket
10mm Socket
15mm Spanner
18mm Spanner
Torx Bit T55
Grease
De-Greaser
Old Rags
Loctite
Torque Settings (Nm)
Wheel Nuts - 85Nm
Bolts/Nuts (through subframe) - 50Nm + 90 degrees
Ball Joint Pinch Bolt - 84Nm
Drop Link Nut - 50Nm
How To Do It
1. Start by loosening the wheel nuts, which are torqued to 85Nm. You will need either a 17mm or 19mm socket to undo them. Don’t forget your locking nut key if you have these fitted!
2. Now the car needs to be jacked up and secured on axle stands. Behind the sill is a box section where the jack can be placed. Ideally use a block of wood when jacking it up if you have the room, unfortunately I didn't as the car is lowered. Once it's high enough place the axle stand on the rear subframe bolt (see photo) or using a block of wood place it on the box section.
3. Once you feel the car is safe enough you can remove the wheel and place it halfway under the car behind the jack. In the unfortunate event that the car did slip it will land on the wheel and not the ground.
4. Now the ball joint pinch bolt needs to be removed. The head of the bolt is a T55 torx bit and the nut requires an 18mm socket. Set the torque wrench to 84Nm and start undoing the nut until the bolt turns with it. You will then need to hold the bolt still using the torx bit. Once the nut is almost off tap it with the hammer to push it out abit. Take the nut off and you should be able to pull it out. If you can't then use the punch to gently tap it out. Photo of pinch bolt is below.
5. The trim will now be removed using a 10mm socket on the 4 screws. These are only hand tight so easy to undo. Carefully remove the trim from around the brake hose/pipe and other components.
6. You will now be able to see the bolts holding the lower arm to the subframe. One of these bolts is under the gearbox and can be a pain to remove. The bolt should go in from the top, which means either the gearbox needs raising or the subframe lowering. There is an alternative method, which is to invert the bolt and cut a small amount of the bolt off so it doesn't foul the gearbox. You can see the bolt in the photo below has been inverted. Many garages will choose this method and I have for the last 3 years with no problems. This guide will be using this method, if you want to insert the bolt the correct way you will need to find additional information.
What Do I Need?
Jack & Axle Stand
Torque Wrench
Power Bar
Pliers
Long Screwdriver
Punch
Ratchets
19mm Socket
18mm Socket
17mm Socket
15mm Socket
10mm Socket
15mm Spanner
18mm Spanner
Torx Bit T55
Grease
De-Greaser
Old Rags
Loctite
Wheel Nuts - 85Nm
How To Do It
