My drivers side window intermittently wont go down goes up fine every time. What i need to know is do i have to remove the door trim to take the switch out through the back or does it come out from the front.
Dude
IIRC, Look inside the hanlde and you should see a cover covering up a screw. Remove the cover with a small flat head screwdriver, Then remove the screw with a X head screw driver. Remove the door handle trim and you can pop the switch outwards and disconet it :L
