1 - 13 of 13 Posts
The never ending project is close to finishing
Just been looking at my TD (1997) could someone shed some light as to where i will find the glow plug relay. I have put on the volt meter but there is no voltage going to the plug, please help :L
TDDI Buff
there should be a constant live feed to any relay afaik thats what i was told.
Theres no current going to the glow plugs them selfs, that why i want to check the relay! Any body know where its located?
TDDI Buff
ah right erm ill have a look see if i can find any info :L
TDDI Buff
R17 black but thats a mk1 haynes manual saying that but im pretty sure theyre the same.
fuse 3 yellow 60a if you need to check that. iirc its the ones that have the clear window on the top.
TDDI Buff
dieselracer said:
under the battery
yeah theres a black one there and theres a black one in the fusebox dunno what its for but could possibly swap them for a temporary check.
Discussion Starter · #12 ·
Okay. I have been playing the relay i have at the mo. When i turn on the ignition there is no voltage to the glow plugs, however i know that there is voltage going to the relay, One permenant and one switched. I suspect the relay is fooked, so i thought i'd just double check everything so:
Whilst the engine was running i put the volt meter onto the glow plug wire and had a voltage of of approx 12.5v, is this something to do with the cold starting and would switch its self off after a short period, or does the feed to the glow plugs stay on all the time?
TDDI Buff
afaik it shouldnt stay on all the time because your glow plugs would burn out thats what the relays for to turn them off.
when i had heated'elec seat wiring put in garryD made me a little loom as i had none of it in the car this had a relay with the wiring, when i put seat on it got hot stayed hot for so long then knocked off. If iwanted heat still i would need to turn the switch off then back on the glow plugs should work in this way too.
1 - 13 of 13 Posts
