Hello. I know there have been several posts regarding knocking. Perhaps you chaps could give me a few ideas if I describe my symptoms.Its a 2.0 zetec year 2000 mk2. I have a feint knocking from the front end, I can hear it most at about 30-40mph on a flat road. also when applying the brakes from about ---mph to 60mph there is some slight judder. something has worn or is loose but I need a starting point on what to look for. The tyres are wearing even at the front, the wheel bearings are ok the brake pads are fine and the discs are newish (10,000 miles old). I cover about 400 miles a week and have only recently noticed it. Thanks for your help.
TDDI Buff
sounds very much like a problem i had either track rods or track rod ends or both.
mine was track rod but had to get the end changed too as the end was stuck on the rod :(
Thanks guys. I'll check these things out when the weather's a little warmer
