I tried to search but got nowhere... :sad:
Just noticed a buzz from nearside light area when sidelights are on. What is it? Should it do that? Is it about to explode? :eek13:
Only found it 'cos I was fitting some nice blue sidelight led bulbs...
In case anyone asks the noise was there with standard side light bulb as well.
It was 49.95
id say it could be the headlamp adjuster constantly stuck on and it has occured quite a bit from what ive seen. Its unlikley to be a bad circuit but possible,
My old ST did that
Try adjusting the headlights up and down a few times
Then it may stop
If not you could whcih is what i did on mine jsut set the switch to 1 and it stopped
