1 - 1 of 1 Posts
1) Find the big loom going through the bulkhead on the passenger side.
2) Pull out the glovebox
3) Find the other side of the big loom behind all those fuses
4) Poke a screwdrive through the gromet, trying to avoid the wires, I found there was space in the gromet above the main bundle. If you got it right, it should appear under the bonnet.
5) I poked a coat hanger through the hole, bent the end over and pulled the new cable back into the car.
6) Pull all slack though, and route through to the boot, or where ever you need it, and reassemble the glovebox.
1 - 1 of 1 Posts
