1 - 13 of 13 Posts
Does anyone have any experience with replacing the thermostat on the Mk3 Mondeo?
Ford seems only to sell the complete housing/thermostat at an extra terrible price, and to install I think the best way to gain access is through the removal of the RH headlamp.
Am I missing something, is there another way?
No your not missing anything. Not too bad a job, half to an hour or so to do. Although small hands help.
Thanks for the reply.
Do I also use a sealant or just rely on the rubber seal on the new housing?
Unfortunately I have big hands and doing the removal reminded me to buy a smaller locking pliers for expanding spring hose clips!
The old thermostat had broken the internal brackets that held the spring compressed, maybe the problem, I don't know.
I didn't use any sealant, rightly or wrongly but no leaks. Make sure the matting face is clean and not pitted first.
All done, thanks for the help.
Great design for removal of headlight and grille, shame about the placement of the stat and the COST.
$10 stat for my MX5, and $350 for the Mondeo, go figure.
I must change the thermostat in my Mk3, is it possible to replace the cover without the thermostat inside? I can then fit an inline thermostat on the coolant outlet to the engine.
MEG Captain
ok , so the exchange rate is about 3:1 but £115 odd pounds for a stat :sad:
Discussion Starter · #8 ·
Not sure, have a read of this quote:
"Duratec HE also pioneers an electronic thermostat, which contributes positively to both fuel economy and wide-open-throttle performance. Unlike traditional thermostats, which open at one temperature threshold, the electronic thermostat is capable of opening at two temperature thresholds. An opening temperature of about 80ºC contributes to full-throttle performance, while a higher opening threshold of 98ºC optimises low-friction operation under normal driving conditions."
Another word for "expensive"!!
Thanks jojonz,
The 98'C is good for shopping cars, as is placing the thermostat on the coolant entry into the engine. I can't see where the bypass hose runs; when you changed the thermostat, did you see if the hose from the radiator to the thermostat branched off anywhere?
Discussion Starter · #10 ·
best thing for you to do is take a look yourself.
Remove the grille and you will see two tent peg shaped pins either side of the RH headlight, remove these and you can take the headlight out. (truly a 30 sec. job!!)
Looks like my thermostat is failing too.
This mk3's electronical thermostat, is it closed and opened mechanicly by wax or is it now electronicaly managed by ecu via thermostat temperature sensor?
I'm asking this because i'd like to test mine in a pot of boiling water. But if it's electronicaly managed it won't function.
Hi Leo
The thermostat opens electrically at the lower temperature approx 70 and mechanically at approx 98'
The ECU instructs electrical operation when there is heavy load on the engine but it's not up to 98'.
Micky said:
Hi Leo
Thanks. Just phoned my local ford parts dealer. Costs around Ł75. Too bad my warranty expired 3 weeks ago :(. But I'll try asking for that "good will" warranty :).
1 - 13 of 13 Posts
