What ho one and all,
As I will be replacing the wishbones, and the rear hydro bolts were previously inserted from below, I thought I would do a bit of prep work by ensuring they will undo.
It's a car, so no such luck!!!! My impact driver is not moving the bolt and I am reluctant to apply too much torque with the breaker bar. Guess I will have to access the nut from the top, which will entail removing the arch liner and perhaps lower the sub-frame for extra room.
Having watched various vids, including the AutoDo, (about 6 minutes), lowering the sub-frame a bit raises some questions that the vids do not address.
The vids show removing the rear s-f bolts to lower the rear of the s-f. This means the s-f is 'supported' only by the front two bolts. Is droop angle likely to damage the front s-f rubber mounts (or bolts)?
Lowering the s-f in this way, what does this do to the steering column? Is it OK?
None of the vids show s-f alignment when reassembling. If the front bolts are not released, is alignment an issue? (I will mark the s-f location and when the job is complete, will be taking her for a wheel alignment.)
Thanks and toodle pip
