1 - 1 of 1 Posts
Hi folks
I've just changed the cambelt, aux belt, water pump, tensioners etc and done oil an filter change on my Mondy. The problem I've got is that although the motor fires up fine and seems to run ok, when turned off there is a sort of 'thump' noise from the inlet manifold area, and I've noticed the plastic manifold sort of pops back up at the same time. It feels almost like a vacuum has been created when the motors running, so i disconnected the i/c just in case but it made no difference.
Immediate thought is that timing may be out, but i would have thought that it wouldn't start and run so well if it was a tooth out ?
Any ideas would be much appreciated as other than stripping it all out again im lost as to what to try tbh.
Thanks for any help (y)
1 - 1 of 1 Posts
