1 - 1 of 1 Posts
Had an issue with stalling and loss of power which would almost stall the car. Would happen hot or cold and intermittently. After paying £35 to have it diagnosed we got back codes: P0087 & P02E1. Panic set in and then I came in here to research the issues. Many thanks to those who either through technical knowledge or experience saved us a fortune with genuinely great advice. We checked the Sensor on the Fuel Rail, all ok. Then moved onto the Fuel Injectors. Removed all, cleaned with Carburetor Cleaner and replaced the copper seals for £13 (bought from Ford). Also noticed an issue with the positive battery connection so replaced that too. The car runs better than ever and the issues, to date, seem solved. So my advice if you come across this issue is try this before forking out for expensive parts. Worth a try. Thanks again.
1 - 1 of 1 Posts
