Hi there,
I have a problem with our mondeo mk2 1998 1800 TD... (yes it's clocking on) but there's gonna have to be a few hundred miles left in her before we can afford to invest in a replacement.
The "pressure release plug" arrowed in the pic below of a Rocker Cover is missing/lost on ours unlike the one shown in the pic.
Missing presumed lost by the roadside somewhere ?
Bearing in mind that these plugs in time can apparently be loosened off from their orignal tight fit by corrosion etc.
I'm presuming that it was a pressure build up inside of the rocker cover, probs caused by possibly a blocked breather pipe.
Or even putting too much oil in the engine as well, which might not help...or maybe a combinaton of the two.
Has anyone had this happen and found that the cause was summat more serious than a blocked breather ? It would be reassuring to know that the cause of this problem was nothing more serious than a blocked breather.
I've scoured the scrappies in the area without any success for a complete Rocker Cover and found also that Ford have discontinued the rocker cover for the model as well.
One guy suggested getting some alloy brazing rods and weld/braze an alloy patch back on it... don't forget... the part is missing I would have to source a small sheet of alloy...and the thought then crossed my mind that maybe I could make up a lid and a rubber gasket and bolt it on ???
Sorry if it was a bit long winded but wadda you reckon ?
