1 - 8 of 8 Posts
Hi everyone!
The question is already in the topic. If you looked at the linked picture below, am I missing any fuses in the engine fusebox? The car came like this and I've been using it for almost three years with no issues, but I recently checked the fuse bays and their meaning through this link: https://www.fordwiki.co.uk/index.php?title=Fuse_%26_Relay_Information
and I see that number F3 fuse is a - 60A - Diesel Engine Heater. I, at least, have never had a fuse there. Is that OK? My Mondeo is one of those that has all the higher specs cabling installed, so is there a possibility there is a heater system that is simply off cos of a missing fuse? What would happen if I pop one in there? Any risk of damaging something?
Anyway, here is the picture of my fuse box. Any suggestions gladly welcome:
Thanks!
F3 = The auxiliary coolan heater...
One of these fitted down on the bulkhead...
The same fusebox is fitted to petrol and diesel cars, as well as different spec vehicles.
So plenty of missing fuses and relays will be normal.
Not all cars had the electric aux heater installed. Etis will say if yours did, if you can get past the registration stuff (not tried it since that was introduced).
Still works, but they get you to change password quite often now.
Previously not changed mine for years.
Never set one up, just used the bits you didn't need to sign in for (spec really). Is it free?
Yep free.
1 - 8 of 8 Posts
