Thanks to TalkFord I quickly learned that the way to get into the back of the lights was to remove the grille and remove the light cluster via the two metal pins (re-fitting these in the dark was a challenge).
However the reason I was re-fitting in the dark is because after an hour I gave up, not because I had replaced the bulb.
Getting the cover off was easy; but looking in to the small hole from the back you can see what looks like a small white plastic helicopter - with 3 blades at 120' to each other, the bottom one seemingly secured by a tiny black plastic boss. Which looks like part of the surround/mounting.
In the middle (the hub of the helicopter) is what looks like a separate, very small rectangular piece of white plastic, just big enough to house two electrical connections, a single red one and a double black one.
I have tried pliers, screwdrivers, fingers (no use of course) - but anxious not to break the electrical connections I have only managed to twist "the helicopter" anticlockwise. But stopped because the twin black connection went very taught.
Anyway. It's still in there! Am I being a pussy; or do these things jam up? Is it a pull, or a twist and pull? Do you have to just apply force; or is the danger of snapping a wire or solder too real?
Some specific insights hugely appreciated...
Slacky
Slacky
