I need to rattle some brains. I have a rumbling noise starts at 1500 rpm to 2000 rpm. Best way of describing is it sounds like exhaust blowing. Had exhaust checked no leaks found. Replaced airfilter (as was damaged in housing) no change replaced EGR (was faulty anyway) no change. It appears to get more audible when warm. I've ran injector cleaner and changed fuel filter too. I can't pinpoint the location.
I've had no loss in power or fuel economy. Noise isn't relative to gear and is still the same with clutch engaged and disengaged.
Tried running with Aircon on and off if it was potentially a pulley issue again no change.
Any help or if anyone had similar it would be a massive help
