1 - 8 of 8 Posts
SMeghead
Anyonoe know why Ford lists two sizes (205/55x16, 215/55x16) for the 1.8TDCI? There's over a £30 difference in price per tyre and my supplier refused to fit the smaller one (despite being shown the handbook) because the larger ones were already on.
Did they refuse to fit a single smaller tyre or were you asking for 2/4 smaller tyres?
If they refused to fit a single one I can't say I blame them as it would be an MOT failure (I think it still is anyway) and they probably just wanted to cover themselves. If they refused to fit 2/4 smaller ones then you need a better supplier.
Depends on the wheels fitted. 205's maybe the steel wheels. You cannot fit different
sizes on the same axle.
Poses issues if you get a punture.
SMeghead
It was a set. The fitter agreed that they were a suitable size for the wheel but his company regs would not allow change. It might be interesting if someone turned up with obviously oversize tyres on....
Mk3 Focus had 215 x 55 x 16 tyres, more recently they changed to 205 x 55 x 16 There are a couple of settings for tyre size in the BCM, with a range of possible sizes otherwise the speedo will read incorrectly .
My guess;
the slightly wider tyres are slightly taller and therefore slightly reduce fuel consumption when undergoing official testing
Holy thread resurrection, Batman
To clarify the original point, the various sizes were on the same 16" wheels.
and to clarify my earlier post
When new, My Mk3 Focus had 215 x 55 x 16 tyres, more recently FORD changed to 205 x 55 x 16
And because I missed this comment
Interesting. How would one go about accessing the tyre size information in the BCM?
Not sure about if it works with the Mondeo MK4 but the FOCCCUS program and an OBD2 device allows you to read and alter settings for the FOCUS MK3. There are other software available such as Elmconfig and ForScan which probably can do the same thing.
On the Focus it's item #70 and possibly other such as item #117
1 - 8 of 8 Posts
