Hi All,
I’m pretty green to these forums. My issue:
Couldn’t get in my car this am. via IR fob. Key in doors didn’t appear to work either. Boot opened with key though and I climbed in that way. Started car ok, couldn’t unlock any doors from inside, but noticed one back door was actually unlocked - I locked the car with the IR fob the night before and got the usual indicator flashes with the double/dead locking - but that door won’t lock from the inside.
I tried the spare key â€" no different. So disconnected battery for probably less than 5 min. Key now worked in the door â€" maybe I wasn’t turning it with enough force not wanting **** it. The fob battery has about 2.7V so I don’t think it’s that. I still can’t unlock the passenger front door with the key.
I noticed that the alarm red indicator on the dash next to the clock is on constantly and flashing brighter. Also when I start the car it does not go out as normal. I then tried resetting the alarm system via the bonnet switch L.H. side above rad. As suggested on http://www.mirez.co.uk but get no horn or flasher indications.
One last thing in the past on occasions the central door locking has locked the doors while I have been driving.
I guess my questions are:
- Should I disconnect the battery for a good half hour?
- or try unplugging the alarm module connectors one by one? â€" they’re a bitch to get to?
- is the back door lock screwed and the cause or just a symptom?
- Any other suggestions are welcome
PS. Sorry I suffer from verbal diarrhoea
