2ltr petrol wouldn't start today. Early Mk1, with 110000 under its belt. Charged battery, just in case, and had a look on here. Fuel pump relay seemed ok, but following someone else's suggestion, floored the throttle and tried again. Hey presto, sprang into life, and seems to run ok now, at least on a quick spin around the block, no fluctuation at idle.
So, glad it's going again, but I just wish I knew what was wrong, in case it happens again. Could it have been some dirt in the fuel system somewhere? Or is the throttle controlled by some electrical widget that could play up. It should really start with no throttle input. Wierd. :shifty:
