1 - 6 of 6 Posts
EQ Heaven,
2 x 30 channel for the fronts and 2 x 20 for the rears.
Will use the SUB part of the crossovers for the full range is going to go through a set of nakamechi active crossovers then to a 800 watt 4 channel amp.
The sub outputs are going to 2 x 1500 watt amps
well at the moment Im at home...... car wouldnt start this morning again .... no spark, so borrowed the wifes to get to work and sorted out the guys then came home.. just had a spot of lunch before I get changed and hit the car with a multimeter and a BIG hammer. Theres LOTS to go in Andy, Im nearly ready to start thinking about HOW its going to go in. Need a few more bits first
annoying, mine only plays up when its really cold, starter motor doesnt engage but ive got waynes old one to fit. good luck finding the problem, not too cold out is it?
only things i want to really do with my install is get rid of the rabbot hutch, amp all the speakers and a make a nice build in the boot showing it all off.
They look expensive and complicated, are they motor driven with remote access or do you have to stop the car get out, tweak and drive off again. Not something I'd be looking at installing in my car.
nope not that expensive and certainly not complicated. Was going to get a symetry from RF but they were all going for a bit too much money. I dont mess with the EQ once its set and there remote for the sub output. Its part of a major install. I really am not going for the tisss tisss tisss thump thump thump that normally comes with installs
1 - 6 of 6 Posts
