Fair point to deffo be taken into consideration but if you are using a 3 output h/u then it should be ok. any less outputs and then the other option may be needed.keith9534 said:Depending on what you are doing has something to do with going for the £99 box or thesplitters AFAIK
If you use a splitter then there is a potential loss of signal strength/quality....may have an inpact on your final result
Just something to bear in mind?
2 6-channel amps :whistling:NMS said:what are you doing that needs 6 pairs of rca's
