Probs only about £200 worth of work there, so if its mint and low mileage then go for it!
However, You could fix it up yourself for under £50, not got a mate that could help you out?
Thanx m8 wiz a bit worried it would be expensive
Premium Member
I've seen worst posted up on here, I recon there more down to there age then milage. Rubbers deteriorate with age as well as miles, just as the brake pipes will do, they might not have done as my miles as one the same age with twice the miles on the clock, but they have still both being exposed to the elements for the same amount of time. Worth the work and money spending on it.
