1 - 20 of 20 Posts
I have moved the 12v Parking/side light bulb into the main beam area of my Headlights :D
This makes the whole of the headlight Light up :woot: :banana:
Has any-one else done this as i'm just wondering will this get throught an M.O.T like this :eyesup: :naughty:
Marty :woot:
it all depends on the brightness i guess being its inthe main beam area it might cause other drivers to think you still got your main beam on but saying that i think the side light is only 5watts,not sure on the mot side of things but i guess as long its not effecting other drives it should be ok
Its only a 12v 5w bulb in the main beam area, all it does is light up the whole of the headlight M8, no chance of people being blinded by it :L thinking i got full beam on :L if they flash there lights thinking i have then on, then 12v 55w full beam will surely let them know otherwise :D
Marty
Phil "THE BOOST" Wootty
rule of thumb m8 if its fitted its got to work for mot purposes.it should pass as my morettes side light is in the main beam lens.looks good,get your arris down to nxt meet so i can have a good looky. :L
thats also the rule for mot if its on the car its got to be working orther wise it wont pass, sorry for not cominting on the look the dose look smart and lol on leting them know your not on main beam lol, i've just got two led bars which are ice blue and i'm always getting flashed for having them on but the think is they are pointing to the road so they cant say there being blinded my them, good work on the lights tho mate looking sweet mate
I'll see what i can do :L You can have a closer look at my lights while i ave a closer look at the next bit of "Bling" i Req :L :thankyousign:
Marty :L
Never knowingly understood
Nice touch Martin m8.
Why don't you go to the place you get your MOT done and ask about it passing or failing in advance of the next MOT. Their answer will give you a chance to (temporarily) de-mod, should it not be able to pass.
Andy.
Administrator
I've thought about moving the sidelight to the main beam bit but I didn't bother doing it as I couldn't be arsed! Looks good, and it works so I don't see why it wouldn't pass the MOT.
Discussion Starter · #11 ·
sorry for not cominting on the look the dose look smart and lol on leting them know your not on main beam lol,good work on the lights tho mate looking sweet mate
:thankyousign:
:D :D :D :D
Discussion Starter · #12 ·
Why don't you go to the place you get your MOT done and ask about it passing or failing (temporarily) de-mod, should it not be able to pass.
Andy.
I always give my M.O.T Tester a :beer: , if he passes or fails my Mondy (Failure usually is some-thing i can overcome, with a litle work)
All i have to do to put it back to the way it shoulb be is simple, i have added a second light socket to the main beam area :L
Marty
Discussion Starter · #13 ·
i'll let you all know how i get on with the dreaded M.O.T. Then you can go from there :L
Marty
Discussion Starter · #14 ·
Keller said:
Nice work Marty!
Did a similare mod myself.. but with a 5w sideligt in the repeater unit :)
:L
I did see your post M8, I was in the middle of doing my mod at the time :eyesup:
Marty :D
ST200 baby
Marty
Marty said:
Keller said:
Nice work Marty!
:L
Marty :D
aha! :L
would be nice to see you setup IRL. Hard to get the right feeling by looking at a pic.
looks good you'll have to come down to tesco so i can have a proper look :D
1 - 20 of 20 Posts
