1 - 2 of 2 Posts
Evening all I've just got a ford maverick on a 02 it's had in the past a new door lock put on , front passenger and I've just notice that its not working off the key fob but will lock unlock manually ? And if I lock the door and get out and try the key fob that dos not work unless I unlock it then it works ok apart from the passenger door . Atb mark
If I understand that correctly - the passenger door is not working off the central locking? How about when you lock the drivers door? If thats the case it just sounds like the central locking motor has failed/not connected or is disconnected?
Cheers
Luke
1 - 2 of 2 Posts
