This may sound daft but how on earth do I change a front headlight bulb on an S reg diesel mondeo?
What do I have to remove??
It looks more complicated than on any other car I've owned?
Retired
I drop the head light unit out.
Remove front grill, 2 torx bolts an a couple of clips.
Then remove the 3 torx bolts holding in the unit. 1 bolt is next to the front grill the other 2 are on the outer edge. 1 adjacent to the top of the wing the other is below it down in side the bonnet area. Should take about 5 mins
MEG Commander
Deffo as said above it's far easier on a MK2 to remove the whole headlamp in order to get the rear cover off to access the bulb and more importantly to replace the back cover on to the light unit.
Steve
